00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.rmi;
00032
00033 import java.io.IOException;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.core.component.gen.Utils;
00037 import org.objectweb.proactive.core.util.log.Loggers;
00038 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00039
00040
00045 public class FileProcess {
00046     protected static Logger logger = ProActiveLogger.getLogger(Loggers.CLASSLOADING);
00047     private java.io.File[] codebases;
00048     protected RequestInfo info;
00049
00050     public FileProcess(String paths, RequestInfo info) {
00051         if (paths != null) {
00052             codebases = findClasspathRoots(paths);
00053         }
00054         this.info = info;
00055     }
00056
00067     public byte[] getBytes() throws ClassNotFoundException {
00068         byte[] b = null;
00069         if (codebases == null) {
00070             try {
00071
00072                 b = getBytesFromResource(info.getClassFileName());
00073             } catch (IOException e) {
00074                 throw new ClassNotFoundException("Cannot find class " +
00075                     info.getClassFileName(), e);
00076             }
00077         } else {
00078             for (int i = 0; i < codebases.length; i++) {
00079                 try {
00080                     if (codebases[i].isDirectory()) {
00081                         b = getBytesFromDirectory(info.getClassFileName(),
00082                                 codebases[i]);
00083                     } else {
00084                         b = getBytesFromArchive(info.getClassFileName(),
00085                                 codebases[i]);
00086                     }
00087                 } catch (java.io.IOException e) {
00088                 }
00089             }
00090         }
00091         if (b != null) {
00092             return b;
00093         }
00094
00095
00096
00097         b = org.objectweb.proactive.core.mop.MOPClassLoader.getMOPClassLoader()
00098                                                            .getClassData(info.getClassFileName());
00099         if (b != null) {
00100             return b;
00101         }
00102
00103
00104
00105         b = Utils.getClassData(info.getClassFileName());
00106         if (b != null) {
00107             return b;
00108         }
00109
00110
00111
00112
00113
00114
00115         throw new ClassNotFoundException("Cannot find class " +
00116             info.getClassFileName());
00117     }
00118
00119
00120
00121
00122
00132     public static byte[] getBytesFromResource(String path)
00133         throws java.io.IOException {
00134         String filename = path.replace('.', '/') + ".class";
00135         java.io.InputStream in = FileProcess.class.getClassLoader()
00136                                                   .getResourceAsStream(filename);
00137         if (in == null) {
00138             return null;
00139         }
00140         int length = in.available();
00141
00142
00143
00144
00145         if (length == -1) {
00146             throw new java.io.IOException("File length is unknown: " +
00147                 filename);
00148         } else {
00149             return getBytesFromInputStream(in, length);
00150         }
00151     }
00152
00163     private byte[] getBytesFromArchive(String path, java.io.File archive)
00164         throws java.io.IOException {
00165         String filename = path.replace('.', '/') + ".class";
00166         java.util.zip.ZipFile jarFile = new java.util.zip.ZipFile(archive);
00167         java.util.zip.ZipEntry zipEntry = jarFile.getEntry(filename);
00168         if (zipEntry == null) {
00169             return null;
00170         }
00171         int length = (int) (zipEntry.getSize());
00172
00173
00174
00175
00176         if (length == -1) {
00177             throw new java.io.IOException("File length is unknown: " +
00178                 filename);
00179         } else {
00180             return getBytesFromInputStream(jarFile.getInputStream(zipEntry),
00181                 length);
00182         }
00183     }
00184
00195     private byte[] getBytesFromDirectory(String path, java.io.File directory)
00196         throws java.io.IOException {
00197         java.io.File f = new java.io.File(directory,
00198                 path.replace('.', java.io.File.separatorChar) + ".class");
00199         if (!f.exists()) {
00200             return null;
00201         }
00202         int length = (int) (f.length());
00203
00204
00205
00206
00207         if (length == 0) {
00208             throw new java.io.IOException("File length is zero: " + path);
00209         } else {
00210             return getBytesFromInputStream(new java.io.FileInputStream(f),
00211                 length);
00212         }
00213     }
00214
00222     private static byte[] getBytesFromInputStream(java.io.InputStream in,
00223         int length) throws java.io.IOException {
00224         java.io.DataInputStream din = new java.io.DataInputStream(in);
00225         byte[] bytecodes = new byte[length];
00226         try {
00227             din.readFully(bytecodes);
00228         } finally {
00229             if (din != null) {
00230                 din.close();
00231             }
00232         }
00233         return bytecodes;
00234     }
00235
00236     private java.io.File[] findClasspathRoots(String classpath) {
00237         String pathSeparator = System.getProperty("path.separator");
00238         java.util.StringTokenizer st = new java.util.StringTokenizer(classpath,
00239                 pathSeparator);
00240         int n = st.countTokens();
00241         java.io.File[] roots = new java.io.File[n];
00242         for (int i = 0; i < n; i++) {
00243             roots[i] = new java.io.File(st.nextToken());
00244         }
00245         return roots;
00246     }
00247 }
