00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.benchmarks.timit.util; 00032 00039 public class FakeTimer extends HierarchicalTimer { 00043 private static final long serialVersionUID = -4023758257227790549L; 00044 00045 private static HierarchicalTimer timer = new FakeTimer(); 00046 00047 public void start(int n) { 00048 } 00049 00050 public void stop(int n) { 00051 } 00052 00053 public void resetTimer(int n) { 00054 } 00055 00056 public void setValue(int n, int t) { 00057 } 00058 00059 public void addValue(int n, int t) { 00060 } 00061 00062 public boolean isStarted(int n) { 00063 return false; 00064 } 00065 00066 public int getElapsedTime() { 00067 return 0; 00068 } 00069 00070 public int getHierarchicalTime() { 00071 return 0; 00072 } 00073 00074 public int getTotalTime() { 00075 return 0; 00076 } 00077 00078 public static HierarchicalTimer getInstance() { 00079 return FakeTimer.timer; 00080 } 00081 }
1.5.1
