00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.mop; 00032 00033 import java.lang.reflect.InvocationTargetException; 00034 00035 00040 class FakeConstructorCall implements ConstructorCall, java.io.Serializable { 00041 private Object target; 00042 00043 // 00044 // -- CONSTRUCTORS ----------------------------------------------- 00045 // 00046 00050 public FakeConstructorCall(Object target) { 00051 this.target = target; 00052 } 00053 00054 // 00055 // -- PUBLIC METHODS ----------------------------------------------- 00056 // 00057 // 00058 // -- implements ConstructorCall ----------------------------------------------- 00059 // 00060 00065 public void makeDeepCopyOfArguments() throws java.io.IOException { 00066 } 00067 00071 public String getTargetClassName() { 00072 return target.getClass().getName(); 00073 } 00074 00080 public Object execute() 00081 throws InvocationTargetException, 00082 ConstructorCallExecutionFailedException { 00083 return target; 00084 } 00085 }
1.5.1
