org/objectweb/proactive/core/process/ExternalProcessDecorator.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.process;
00032
00033
00037 public interface ExternalProcessDecorator extends ExternalProcess {
00038
00042     public static final int APPEND_TO_COMMAND_COMPOSITION = 1;
00043
00048     public static final int SEND_TO_OUTPUT_STREAM_COMPOSITION = 2;
00049
00054     public static final int GIVE_COMMAND_AS_PARAMETER = 3;
00055
00060     public static final int COPY_FILE_AND_APPEND_COMMAND = 4;
00061
00067     public ExternalProcess getTargetProcess();
00068
00074     public void setTargetProcess(ExternalProcess targetProcess);
00075
00081     public void setCompositionType(int compositionType);
00082 }
Generated on Mon Jan 22 15:16:08 2007 for ProActive by  doxygen 1.5.1
