00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.calcium.statistics; 00032 00033 import java.io.Serializable; 00034 00035 public class Exercise implements Serializable{ 00036 00037 private long computationTime; 00038 private int numberExecutedTimes; 00039 00040 Exercise(){ 00041 computationTime=0; 00042 } 00043 00044 Exercise(Timer timer) { 00045 this.computationTime = timer.getTime(); 00046 this.computationTime = 1; 00047 } 00048 00052 public long getComputationTime() { 00053 return computationTime; 00054 } 00055 00059 public long getNumberExecutedTimes() { 00060 return numberExecutedTimes; 00061 } 00062 00066 void incrementComputationTime(Timer time) { 00067 this.computationTime += time.getTime(); 00068 numberExecutedTimes += time.getNumberOfActivatedTimes(); 00069 } 00070 00071 void incrementComputationTime(Exercise exercise) { 00072 this.computationTime += exercise.computationTime; 00073 this.numberExecutedTimes += exercise.numberExecutedTimes; 00074 } 00075 00076 public String toString(){ 00077 return computationTime+"/"+numberExecutedTimes; 00078 } 00079 }
1.5.1
