00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.group; 00032 00033 import java.util.Iterator; 00034 import java.util.Vector; 00035 00036 00042 public class ExceptionListException extends RuntimeException { 00043 00045 private Vector<ExceptionInGroup> list; 00046 00050 public ExceptionListException() { 00051 super("Exception list, only one cause in the stacktrace"); 00052 this.list = new Vector<ExceptionInGroup>(); 00053 } 00054 00059 public synchronized void add(ExceptionInGroup exception) { 00060 if (getCause() == this) { 00061 initCause(exception); 00062 } 00063 this.list.add(exception); 00064 } 00065 00069 public void clear() { 00070 this.list.clear(); 00071 } 00072 00077 public Iterator<ExceptionInGroup> iterator() { 00078 return this.list.iterator(); 00079 } 00080 00085 public int size() { 00086 return this.list.size(); 00087 } 00088 00093 public boolean isEmpty() { 00094 return this.list.isEmpty(); 00095 } 00096 }
