00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.ext.security.securityentity;
00032
00033 import java.io.IOException;
00034 import java.io.Serializable;
00035 import java.security.cert.CertificateEncodingException;
00036 import java.security.cert.X509Certificate;
00037
00038 import org.apache.log4j.Logger;
00039 import org.objectweb.proactive.core.util.log.Loggers;
00040 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00041 import org.objectweb.proactive.ext.security.ProActiveSecurity;
00042
00043
00050 public abstract class Entity implements Serializable {
00051 static Logger logger = ProActiveLogger.getLogger(Loggers.SECURITY);
00052 protected X509Certificate applicationCertificate;
00053 protected byte[] encodedApplicationCertificate;
00054 protected X509Certificate certificate;
00055
00056 public X509Certificate getApplicationCertificate() {
00057 return applicationCertificate;
00058 }
00059
00060 public X509Certificate getCertificate() {
00061 return certificate;
00062 }
00063
00064 public abstract String getName();
00065
00066 public abstract boolean equals(Entity e);
00067
00068
00069 private void writeObject(java.io.ObjectOutputStream out)
00070 throws IOException {
00071 if (applicationCertificate != null) {
00072 try {
00073 encodedApplicationCertificate = applicationCertificate.getEncoded();
00074 } catch (CertificateEncodingException e) {
00075 e.printStackTrace();
00076 }
00077 }
00078 out.defaultWriteObject();
00079 }
00080
00081 private void readObject(java.io.ObjectInputStream in)
00082 throws IOException, ClassNotFoundException {
00083 in.defaultReadObject();
00084 if (encodedApplicationCertificate != null) {
00085 applicationCertificate = ProActiveSecurity.decodeCertificate(encodedApplicationCertificate);
00086 }
00087 }
00088 }
