00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.security.securityentity; 00032 00033 import java.io.Serializable; 00034 import java.security.cert.X509Certificate; 00035 00036 00043 public class EntityCertificate extends Entity implements Serializable { 00044 00048 public EntityCertificate(X509Certificate applicationCertificate, 00049 X509Certificate certificate) { 00050 super(); 00051 this.applicationCertificate = applicationCertificate; 00052 this.certificate = certificate; 00053 } 00054 00055 public String getName() { 00056 return null; 00057 } 00058 00059 /* (non-Javadoc) 00060 * @see org.objectweb.proactive.ext.security.Entity#equals(org.objectweb.proactive.ext.security.Entity) 00061 */ 00062 public boolean equals(Entity e) { 00063 return e.getCertificate().equals(certificate); 00064 } 00065 }
1.5.1
