00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.util.timer;
00032
00033 import java.util.Random;
00034
00035
00041 public class EWMATimer extends AverageMicroTimer {
00042 protected double alpha;
00043 protected double average;
00044
00045 public EWMATimer(String s, double alpha) {
00046 super(s);
00047 this.alpha = alpha;
00048 }
00049
00050 public void stop() {
00051 if (running) {
00052 timer.stop();
00053 currentElapsed += timer.getCumulatedTime();
00054 this.total += currentElapsed;
00055 this.nbrValues++;
00056 this.average = ((this.average * this.alpha) +
00057 ((1 - this.alpha) * currentElapsed));
00058 currentElapsed = 0;
00059 running = false;
00060 }
00061 }
00062
00063 public double getAverage() {
00064 return this.average;
00065 }
00066
00067 public void reset() {
00068 super.reset();
00069 this.average = 0;
00070 }
00071
00072 public static void main(String[] args) {
00073 int max = 100;
00074 Random r = new Random();
00075 long rValue;
00076 double[] ewmaMemory = new double[max];
00077 double[] ewmaMemory2 = new double[max];
00078 double[] tMemory = new double[max];
00079
00080
00081 EWMATimer ewmat = new EWMATimer("EWMA", 0.9);
00082 EWMATimer ewmat2 = new EWMATimer("EWMA", 0.5);
00083 TimerWithMemory tm = new TimerWithMemory("Memory");
00084 AverageMicroTimer t = new AverageMicroTimer("MicroTimer");
00085 for (int i = 0; i < 100; i++) {
00086 ewmat.start();
00087 t.start();
00088 ewmat2.start();
00089 tm.start();
00090 try {
00091 Thread.sleep(r.nextInt(200));
00092 } catch (InterruptedException e) {
00093 e.printStackTrace();
00094 }
00095 ewmat.stop();
00096 t.stop();
00097 ewmat2.stop();
00098 tm.stop();
00099 ewmaMemory[i] = ewmat.getAverage();
00100 ewmaMemory2[i] = ewmat2.getAverage();
00101 tMemory[i] = t.getAverage();
00102 }
00103 long[] memory = tm.getMemory();
00104 System.err.println("Dumping memory ");
00105 for (int i = 0; i < ewmaMemory.length; i++) {
00106 System.out.println(tMemory[i] + " " + ewmaMemory[i] + " " +
00107 ewmaMemory2[i] + " " + memory[i]);
00108 }
00109 System.err.println(
00110 "Command in gnuplot: plot 'file' using 1 title 'Average' with lp, 'file' using 2 title 'EMWA 0.9' with lp, 'file' using 3 title 'EWMA 0.5' with lp, 'file' using 4 title 'Raw' with lp");
00111 }
00112 }
