00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process; 00032 00033 import java.io.IOException; 00034 00035 00044 public class DependentListProcess 00045 extends AbstractSequentialListProcessDecorator { 00046 public DependentListProcess() { 00047 super(); 00048 } 00049 00055 public void addProcessToList(ExternalProcess process) { 00056 if (processes.size() == 0) { 00057 processes.add(process); 00058 } 00059 // process has to be an instance of dependentProcess 00060 // implements DependentProcess 00061 else if (process instanceof DependentProcess) { 00062 this.processes.add(process); 00063 } else { 00064 throw new ClassCastException( 00065 " process must be a dependent process !"); 00066 } 00067 } 00068 00072 public String getProcessId() { 00073 return "dps"; 00074 } 00075 00076 public boolean isSequential() { 00077 return true; 00078 } 00079 00080 public boolean isDependent() { 00081 return true; 00082 } 00083 00084 public boolean isHierarchical() { 00085 return false; 00086 } 00087 00088 public String getHostname() { 00089 // TODO Auto-generated method stub 00090 return null; 00091 } 00092 00093 public void setHostname(String hostname) { 00094 // TODO Auto-generated method stub 00095 } 00096 00097 protected ExternalProcess createProcess() { 00098 // TODO Auto-generated method stub 00099 return null; 00100 } 00101 00102 public void startProcess() throws IOException { 00103 // TODO Auto-generated method stub 00104 } 00105 }
