00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.benchmarks.timit.util.observing.defaultobserver;
00032
00033 import java.util.Vector;
00034
00035 import org.objectweb.proactive.benchmarks.timit.util.observing.EventData;
00036
00041 public class DefaultEventData implements EventData {
00042
00046     private static final long serialVersionUID = -8362004552051089021L;
00047
00048     public static final int MIN = 0;
00049
00050     public static final int MAX = 1;
00051
00052     public static final int AVERAGE = 2;
00053
00054     public static final int SUM = 3;
00055
00056     private String name;
00057
00058     private int collapseOperation;
00059
00060     private int notifyOperation;
00061
00062     private double value, result;
00063
00064     private int nbNotify;
00065
00066     private Vector<Object> collapsedValues;
00067
00069     public DefaultEventData(String name, int collapseOperation,
00070             int notifyOperation) {
00071
00072         this.name = name;
00073         this.collapseOperation = collapseOperation;
00074         this.notifyOperation = notifyOperation;
00075         this.nbNotify = 0;
00076         this.result = 0;
00077
00078         switch (this.notifyOperation) {
00079         case DefaultEventData.MIN:
00080             this.value = Double.MAX_VALUE;
00081             break;
00082         case DefaultEventData.MAX:
00083             this.value = Double.MIN_VALUE;
00084             break;
00085         default:
00086             this.value = 0;
00087         }
00088     }
00089
00090     public void performNotifyOperation(double value) {
00091         switch (this.notifyOperation) {
00092         case DefaultEventData.MIN:
00093             if (value < this.value) {
00094                 this.value = value;
00095             }
00096             break;
00097         case DefaultEventData.MAX:
00098             if (value > this.value) {
00099                 this.value = value;
00100             }
00101             break;
00102         case DefaultEventData.AVERAGE:
00103             this.nbNotify++;
00104             this.value += value;
00105             break;
00106         default:
00107             this.value += value;
00108         }
00109     }
00110
00111     public void setData(Object object) {
00112     }
00113
00114     public Object getData() {
00115         if (this.notifyOperation == DefaultEventData.AVERAGE) {
00116             this.value /= this.nbNotify;
00117         }
00118         return this.value;
00119     }
00120
00121     public String getName() {
00122         return this.name;
00123     }
00124
00128     public Object collapseWith(EventData anotherData, int anotherRank) {
00129         if (this.collapsedValues == null) {
00130             this.collapsedValues = new Vector<Object>();
00131
00132             if (this.notifyOperation == DefaultEventData.AVERAGE) {
00133                 this.value /= this.nbNotify;
00134             }
00135             this.collapsedValues.add(this.value);
00136         }
00137         if (anotherData.equals(this)) {
00138             this.result = this.value;
00139             return this.collapsedValues;
00140         }
00141
00142         this.collapsedValues.add(anotherData.getData());
00143         switch (this.collapseOperation) {
00144         case DefaultEventData.MIN:
00145             this.result = Double.MAX_VALUE;
00146             for (int i = 0; i < this.collapsedValues.size(); i++) {
00147                 this.result = ((Double) this.collapsedValues.get(i) < this.result ? (Double) this.collapsedValues
00148                         .get(i)
00149                         : this.result);
00150             }
00151             break;
00152         case DefaultEventData.MAX:
00153             this.result = Double.MIN_VALUE;
00154             for (int i = 0; i < this.collapsedValues.size(); i++) {
00155                 this.result = ((Double) this.collapsedValues.get(i) > this.result ? (Double) this.collapsedValues
00156                         .get(i)
00157                         : this.result);
00158             }
00159             break;
00160         case DefaultEventData.AVERAGE:
00161             this.result = 0;
00162             for (int i = 0; i < this.collapsedValues.size(); i++) {
00163                 this.result += (Double) this.collapsedValues.get(i);
00164             }
00165             this.result /= this.collapsedValues.size();
00166             break;
00167         default:
00168             this.result = 0;
00169             for (int i = 0; i < this.collapsedValues.size(); i++) {
00170                 this.result += (Double) this.collapsedValues.get(i);
00171             }
00172             break;
00173         }
00174         return this.collapsedValues;
00175     }
00176
00177     public Object getFinalized() {
00178         return this.result;
00179     }
00180
00181     public String toString() {
00182         return "" + this.result;
00183     }
00184 }
