org/objectweb/proactive/benchmarks/timit/config/ConfigChart.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.benchmarks.timit.config;
00032
00033 import org.jdom.Element;
00034 import org.objectweb.proactive.benchmarks.timit.util.charts.Chart;
00035
00036 public class ConfigChart extends Tag {
00037
00038     public ConfigChart(Element eChart) {
00039         super(eChart);
00040     }
00041
00042     public String get(String name) {
00043         name = name.toLowerCase();
00044         String value = super.get(name);
00045
00046         if (value != null) {
00047             return value;
00048         }
00049
00050         // Specify default values
00051         if (name.equalsIgnoreCase("width")) {
00052             return "800";
00053         }
00054         if (name.equalsIgnoreCase("height")) {
00055             return "600";
00056         }
00057         if (name.equalsIgnoreCase("scalemode")) {
00058             return ""+Chart.Scale.DEFAULT;
00059         }
00060         if (name.equalsIgnoreCase("legendformatmode")) {
00061             return ""+Chart.LegendFormat.DEFAULT;
00062         }
00063         if (name.equalsIgnoreCase("alpha")) {
00064             return "255";
00065         }
00066         if (name.equalsIgnoreCase("filter")) {
00067             return "";
00068         }
00069         if (name.equalsIgnoreCase("subtitle")) {
00070             return "";
00071         }
00072
00073         throw new RuntimeException("Variable chart.'" + name
00074                 + "' missing in configuration file");
00075     }
00076
00077     public static Chart.Scale scaleValue( String scaleMode ) {
00078         if ( scaleMode.equalsIgnoreCase("LINEAR")) {
00079             return Chart.Scale.LINEAR;
00080         }
00081         if ( scaleMode.equalsIgnoreCase("LOGARITHMIC")) {
00082             return Chart.Scale.LOGARITHMIC;
00083         }
00084         return Chart.Scale.DEFAULT;
00085     }
00086
00087     public static Chart.LegendFormat legendValue( String legendMode ) {
00088         if ( legendMode.equalsIgnoreCase("NONE")) {
00089             return Chart.LegendFormat.NONE;
00090         }
00091         if ( legendMode.equalsIgnoreCase("POW10")) {
00092             return Chart.LegendFormat.POW10;
00093         }
00094         if ( legendMode.equalsIgnoreCase("POW2")) {
00095             return Chart.LegendFormat.POW2;
00096         }
00097         return Chart.LegendFormat.DEFAULT;
00098     }
00099 }
Generated on Mon Jan 22 15:16:04 2007 for ProActive by  doxygen 1.5.1
