00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.util.timer;
00032
00033 import java.io.IOException;
00034 import java.io.ObjectInputStream;
00035 import java.io.ObjectOutputStream;
00036 import java.io.Serializable;
00037 import java.util.HashMap;
00038 import java.util.Iterator;
00039 import java.util.Random;
00040
00041 import org.objectweb.proactive.core.util.profiling.PAProfilerEngine;
00042 import org.objectweb.proactive.core.util.profiling.Timer;
00043
00044
00051 public class CompositeAverageMicroTimer extends AverageMicroTimer
00052 implements Timer, Serializable {
00053 private HashMap<String, Timer> timerMap = new HashMap<String, Timer>();
00054 private Timer activeTimer = null;
00055
00056 private CompositeAverageMicroTimer() {
00057 }
00058
00059 public CompositeAverageMicroTimer(String name) {
00060 this.name = name;
00061 }
00062
00063 public void start() {
00064 this.activeTimer.start();
00065 }
00066
00067 public void resume() {
00068 this.activeTimer.resume();
00069 }
00070
00071 public void pause() {
00072 this.activeTimer.pause();
00073 }
00074
00075 public void stop() {
00076 if (this.activeTimer != null) {
00077 this.activeTimer.stop();
00078 }
00079 }
00080
00081 public void reset() {
00082 this.activeTimer.reset();
00083 }
00084
00085 public long getCumulatedTime() {
00086 long time = 0;
00087 Iterator<Timer> it = timerMap.values().iterator();
00088 while (it.hasNext()) {
00089 Timer t = it.next();
00090 time += t.getCumulatedTime();
00091 }
00092 return time;
00093 }
00094
00095 public int getNumberOfValues() {
00096 int values = 0;
00097 Iterator<Timer> it = timerMap.values().iterator();
00098 while (it.hasNext()) {
00099 Timer t = it.next();
00100 values += t.getNumberOfValues();
00101 }
00102 return values;
00103 }
00104
00108 public double getAverage() {
00109 int values = 0;
00110 long time = 0;
00111 Iterator<Timer> it = timerMap.values().iterator();
00112 while (it.hasNext()) {
00113 Timer t = it.next();
00114 values += t.getNumberOfValues();
00115 time += t.getCumulatedTime();
00116 }
00117 return ((values > 0) ? ((double) time / values) : (-1));
00118 }
00119
00120 public String toString() {
00121 StringBuilder tmp = new StringBuilder();
00122
00123 tmp.append("Number of measures: ").append(this.getNumberOfValues());
00124 tmp.append("\nTotal time measured: ").append(this.getCumulatedTime());
00125 tmp.append("\nAverage time: ").append(this.getAverage()).append("\n");
00126
00127 Iterator<Timer> it = timerMap.values().iterator();
00128 while (it.hasNext()) {
00129 Timer t = it.next();
00130 tmp.append(" ").append(t.getName()).append("\n");
00131 tmp.append(" ").append("Number of measures: ").append(t.getNumberOfValues());
00132 tmp.append("\n ").append("Total time measured: ").append(t.getCumulatedTime());
00133 tmp.append("\n ").append("Average time: ")
00134 .append(t.getAverage()).append("\n");
00135 }
00136
00137 return tmp.toString();
00138 }
00139
00140 public void dump() {
00141 int ln = name.length();
00142 StringBuilder tmp = new StringBuilder();
00143 tmp.append("------- ").append(name).append(" -------\n");
00144 tmp.append(this.toString());
00145 for (int i = 0; i <= (ln + 16); i++) {
00146 tmp.append("-");
00147 }
00148 System.out.println(tmp.append("\n").toString());
00149 }
00150
00151 public void setTimer(String name) {
00152 String realName = this.name + "." + name;
00153 this.activeTimer = timerMap.get(realName);
00154 if (this.activeTimer == null) {
00155
00156 this.activeTimer = new AverageMicroTimer(realName);
00157 timerMap.put(realName, this.activeTimer);
00158 }
00159 }
00160
00161 public Timer getActiveTimer() {
00162 return this.activeTimer;
00163 }
00164
00165 private void writeObject(ObjectOutputStream out) throws IOException {
00166 this.stop();
00167 this.dump();
00168 out.defaultWriteObject();
00169 }
00170
00171 private void readObject(ObjectInputStream in)
00172 throws IOException, ClassNotFoundException {
00173 in.defaultReadObject();
00174 System.out.println("CompositeAverageMicroTimer.readObject()");
00175
00176 PAProfilerEngine.registerTimer(this);
00177 }
00178
00179 public static void main(String[] args) {
00180 CompositeAverageMicroTimer timer = new CompositeAverageMicroTimer(
00181 "Test");
00182 PAProfilerEngine.registerTimer(timer);
00183 System.out.println("Using sub-timer 1");
00184 timer.setTimer("1");
00185 Random rand = new Random();
00186 try {
00187 for (int i = 0; i < 2; i++) {
00188 timer.start();
00189 Thread.sleep(400 + rand.nextInt(1000));
00190 timer.stop();
00191 }
00192 System.out.println("Using sub-timer 2");
00193 timer.setTimer("2");
00194 for (int i = 0; i < 2; i++) {
00195 timer.start();
00196 Thread.sleep(400 + rand.nextInt(1000));
00197 timer.stop();
00198 }
00199 } catch (Exception e) {
00200 e.printStackTrace();
00201 }
00202 }
00203 }
