org/objectweb/proactive/benchmarks/timit/util/observing/commobserv/CommEventObserver.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.benchmarks.timit.util.observing.commobserv;
00032
00033 import org.objectweb.proactive.benchmarks.timit.util.observing.EventData;
00034 import org.objectweb.proactive.benchmarks.timit.util.observing.EventObservable;
00035 import org.objectweb.proactive.benchmarks.timit.util.observing.EventObserver;
00036
00043 public class CommEventObserver implements EventObserver {
00047     private static final long serialVersionUID = 8068073524780563668L;
00049     private CommEventData commStatData;
00050     private String name;
00051
00063     public CommEventObserver(String name, int groupSize, int subjectRank) {
00064         this.commStatData = new CommEventData(name, groupSize, subjectRank);
00065         this.name = name;
00066     }
00067
00076     public void update(EventObservable s, Object arg) {
00077         if (arg instanceof CommEvent && ((CommEvent) arg).getObserver() == this) {
00078             this.commStatData.mark(((CommEvent) arg).getDestRank(),
00079                     ((CommEvent) arg).getValue());// increment the value each
00080                                                     // time we speak to sombody
00081         }
00082     }
00083
00089     public EventData getEventData() {
00090         return this.commStatData;
00091     }
00092
00096     public String getName() {
00097         return this.name;
00098     }
00099 }
Generated on Mon Jan 22 15:16:04 2007 for ProActive by  doxygen 1.5.1
