00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.benchmarks.timit.util.observing.commobserv;
00032
00033 import org.objectweb.proactive.benchmarks.timit.util.observing.EventData;
00034
00041 public class CommEventData implements EventData {
00042
00046 private static final long serialVersionUID = -5062574158941020818L;
00047
00048 private String name;
00049
00050 private int subjectRank;
00051
00052 private int[] markedCommunication;
00053
00054 private int[][] allValues;
00055
00069 public CommEventData(String name, int groupSize, int subjectRank) {
00070 this.name = name;
00071 this.markedCommunication = new int[groupSize];
00072 this.subjectRank = subjectRank;
00073 }
00074
00082 public void setData(Object object) {
00083 this.markedCommunication = (int[]) object;
00084 }
00085
00091 public String getName() {
00092 return this.name;
00093 }
00094
00101 public Object getData() {
00102 return this.markedCommunication.clone();
00103 }
00104
00125 public Object collapseWith(EventData anotherData, int anotherRank) {
00126 int length = this.markedCommunication.length;
00127 if (this.allValues == null) {
00128 this.allValues = new int[length][length];
00129 System.arraycopy(this.markedCommunication, 0,
00130 this.allValues[this.subjectRank], 0, length);
00131 }
00132 if (anotherData.equals(this)) {
00133 return this.allValues.clone();
00134 }
00135
00136 int[] anotherCommArray = (int[]) anotherData.getData();
00137
00138 for (int i = 0; i < length; i++) {
00139 this.allValues[anotherRank][i] += anotherCommArray[i];
00140 }
00141
00142 return this.allValues.clone();
00143 }
00144
00153 public void mark(int targetRank, double value) {
00154 this.markedCommunication[targetRank] += (int) value;
00155 }
00156
00162 public Object getFinalized() {
00163 return this.allValues.clone();
00164 }
00165
00172 public String toString() {
00173
00174 if (this.allValues == null) {
00175 return "";
00176 }
00177 String res = "\n";
00178
00179 int maxLength = ("" + getMaxValue(this.allValues)).length();
00180 StringBuilder sb = null;
00181 String[] lines = new String[this.allValues.length];
00182 int i, j;
00183
00184 for (i = 0; i < this.allValues.length; i++) {
00185 lines[i] = "";
00186 for (j = 0; j < this.allValues.length; j++) {
00187 sb = new StringBuilder(lines[i]);
00188 sb.append(String.format("%1$" + maxLength + "s",
00189 this.allValues[i][j])
00190 + " ");
00191 lines[i] = sb.toString();
00192 }
00193 }
00194
00195 for (i = lines.length - 1; i >= 0; i--) {
00196 res += lines[i] + "\n";
00197 }
00198
00199 return res;
00200 }
00201
00209 public static int getMaxValue(int[][] a) {
00210 int i, j, max = 0;
00211
00212 for (i = 0; i < a.length; i++) {
00213 for (j = 0; j < a.length; j++) {
00214 if (a[i][j] > max) {
00215 max = a[i][j];
00216 }
00217 }
00218 }
00219 return max;
00220 }
00221 }
