org/objectweb/proactive/core/process/rocks/ClusterForkProcess.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.process.rocks;
00032
00033 import org.objectweb.proactive.core.process.AbstractExternalProcessDecorator;
00034 import org.objectweb.proactive.core.process.ExternalProcess;
00035 import org.objectweb.proactive.core.process.UniversalProcess;
00036
00037
00038 public class ClusterForkProcess extends AbstractExternalProcessDecorator {
00039     final protected String DEFAULT_COMMAND = "cluster-fork";
00040
00041     public ClusterForkProcess() {
00042         super();
00043         command_path = DEFAULT_COMMAND;
00044         hostname = null;
00045     }
00046
00047     public ClusterForkProcess(ExternalProcess _targetProcess) {
00048         super(_targetProcess);
00049         command_path = DEFAULT_COMMAND;
00050         hostname = null;
00051     }
00052
00053     /* ==== AbstractExternalProcessDecorator ==== */
00054     protected String internalBuildCommand() {
00055         if (logger.isDebugEnabled()) {
00056             logger.debug("cluster-fork command is " + command_path);
00057         }
00058         return command_path + " --bg ";
00059     }
00060
00061     public UniversalProcess getFinalProcess() {
00062         checkStarted();
00063         return targetProcess;
00064     }
00065
00066     public int getNodeNumber() {
00067         return UNKNOWN_NODE_NUMBER;
00068     }
00069
00070     public String getProcessId() {
00071         return "clusterfork_" + targetProcess.getProcessId();
00072     }
00073 }
Generated on Mon Jan 22 15:16:09 2007 for ProActive by  doxygen 1.5.1
