00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.rmi; 00032 00033 import org.objectweb.proactive.core.config.ProActiveConfiguration; 00034 import org.objectweb.proactive.core.ssh.SshParameters; 00035 00036 00037 public class ClassServerHelper { 00038 00042 protected ClassServer currentClassServer; 00043 protected String classpath; 00044 protected boolean shouldCreateClassServer = true; 00045 00046 // 00047 // -- Constructors ----------------------------------------------- 00048 // 00049 public ClassServerHelper() { 00050 if ((System.getSecurityManager() == null) && 00051 !("false".equals(System.getProperty("proactive.securitymanager")))) { 00052 System.setSecurityManager(new java.rmi.RMISecurityManager()); 00053 } 00054 if (ProActiveConfiguration.osgiServletEnabled()) { 00055 this.shouldCreateClassServer = false; 00056 } 00057 } 00058 00059 // 00060 // -- PUBLIC METHODS ----------------------------------------------- 00061 // 00062 public String getClasspath() { 00063 return classpath; 00064 } 00065 00066 public void setClasspath(String v) { 00067 classpath = v; 00068 } 00069 00070 public int getClassServerPortNumber() { 00071 if (currentClassServer == null) { 00072 return -1; 00073 } 00074 return ClassServer.getServerSocketPort(); 00075 } 00076 00077 public boolean shouldCreateClassServer() { 00078 return shouldCreateClassServer; 00079 } 00080 00081 public void setShouldCreateClassServer(boolean v) { 00082 shouldCreateClassServer = v; 00083 } 00084 00085 public synchronized String initializeClassServer() 00086 throws java.io.IOException { 00087 00088 if (ProActiveConfiguration.osgiServletEnabled()) { 00089 return this.getCodebase(); 00090 } 00091 00092 if (!shouldCreateClassServer) { 00093 return null; // don't bother 00094 } 00095 if (currentClassServer != null) { 00096 return this.getCodebase(); // already created for this VM 00097 } 00098 if (classpath == null) { 00099 currentClassServer = new ClassServer(); 00100 } else { 00101 currentClassServer = new ClassServer(classpath); 00102 } 00103 String codebase = this.getCodebase(); 00104 System.setProperty("java.rmi.server.codebase", codebase); 00105 00106 return codebase; 00107 } 00108 00109 // 00110 // -- PRIVATE METHODS ----------------------------------------------- 00111 // 00112 private String getCodebase() { 00113 String codebase; 00114 if (SshParameters.getSshTunneling()) { 00115 codebase = "httpssh://" + currentClassServer.getHostname() + ":" + 00116 ClassServer.getServerSocketPort() + "/"; 00117 } else if (ProActiveConfiguration.osgiServletEnabled()) { 00118 codebase = ClassServerServlet.getUrl() + "doc"; 00119 } else { 00120 codebase = "http://" + currentClassServer.getHostname() + ":" + 00121 ClassServer.getServerSocketPort() + "/"; 00122 } 00123 00124 return codebase; 00125 } 00126 }
1.5.1
