00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.util;
00032
00033 import java.util.Iterator;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.proactive.core.util.log.Loggers;
00037 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00038
00039
00053 public class CircularArrayList extends java.util.AbstractList
00054     implements java.util.List, java.io.Serializable {
00055     static Logger logger = ProActiveLogger.getLogger(Loggers.UTIL);
00056     private static final int DEFAULT_SIZE = 5;
00057     protected Object[] array;
00058
00059
00060
00061
00062
00063     protected int head = 0;
00064
00065
00066
00067
00068
00069     protected int tail = 0;
00070
00071
00072
00073
00074     protected int size = 0;
00075
00076     public CircularArrayList() {
00077         this(DEFAULT_SIZE);
00078     }
00079
00080     public CircularArrayList(int size) {
00081         array = new Object[size];
00082     }
00083
00084     public CircularArrayList(java.util.Collection c) {
00085         tail = c.size();
00086         array = new Object[c.size()];
00087         c.toArray(array);
00088     }
00089
00090     public String toString() {
00091         StringBuilder sb = new StringBuilder();
00092         sb.append("CircularArray size=");
00093         sb.append(size);
00094         sb.append("\n");
00095         for (int i = 0; i < size; i++) {
00096             sb.append("[");
00097             sb.append(convert(i));
00098             sb.append("]=>");
00099             sb.append(array[convert(i)]);
00100             sb.append(", ");
00101         }
00102         sb.append("\n");
00103         return sb.toString();
00104     }
00105
00106     public static void main(String[] args) {
00107         CircularArrayList c = new CircularArrayList(5);
00108         c.add(0, new Integer(8));
00109         logger.info(c.toString());
00110         c.add(0, new Integer(7));
00111         logger.info(c.toString());
00112         c.add(0, new Integer(6));
00113         logger.info(c.toString());
00114         c.add(0, new Integer(5));
00115         logger.info(c.toString());
00116         c.add(0, new Integer(4));
00117         logger.info(c.toString());
00118         c.add(0, new Integer(3));
00119         logger.info(c.toString());
00120         c.add(0, new Integer(2));
00121         logger.info(c.toString());
00122         c.add(0, new Integer(1));
00123         logger.info(c.toString());
00124         c.add(0, new Integer(0));
00125         logger.info(c.toString());
00126     }
00127
00128     public boolean isEmpty() {
00129         return head == tail;
00130     }
00131
00132
00133
00134
00135
00136     public void ensureCapacity(int minCapacity) {
00137         int oldCapacity = array.length;
00138         if (minCapacity > oldCapacity) {
00139             int newCapacity = ((oldCapacity * 3) / 2) + 1;
00140             if (newCapacity < minCapacity) {
00141                 newCapacity = minCapacity;
00142             }
00143             Object[] newData = new Object[newCapacity];
00144             toArray(newData);
00145             tail = size;
00146             head = 0;
00147             array = newData;
00148         }
00149     }
00150
00151     public int size() {
00152
00153
00154         return size;
00155     }
00156
00157     public boolean contains(Object elem) {
00158         return indexOf(elem) >= 0;
00159     }
00160
00161     public int indexOf(Object elem) {
00162         if (elem == null) {
00163             for (int i = 0; i < size; i++)
00164                 if (array[convert(i)] == null) {
00165                     return i;
00166                 }
00167         } else {
00168             for (int i = 0; i < size; i++)
00169                 if (elem.equals(array[convert(i)])) {
00170                     return i;
00171                 }
00172         }
00173         return -1;
00174     }
00175
00176     public int lastIndexOf(Object elem) {
00177         if (elem == null) {
00178             for (int i = size - 1; i >= 0; i--)
00179                 if (array[convert(i)] == null) {
00180                     return i;
00181                 }
00182         } else {
00183             for (int i = size - 1; i >= 0; i--)
00184                 if (elem.equals(array[convert(i)])) {
00185                     return i;
00186                 }
00187         }
00188         return -1;
00189     }
00190
00191     public Object[] toArray() {
00192         return toArray(new Object[size]);
00193     }
00194
00195     public Object[] toArray(Object[] a) {
00196
00197         if (size == 0) {
00198             return a;
00199         }
00200         if (a.length < size) {
00201             a = (Object[]) java.lang.reflect.Array.newInstance(a.getClass()
00202        .getComponentType(),
00203                     size);
00204         }
00205         if (head < tail) {
00206             System.arraycopy(array, head, a, 0, tail - head);
00207         } else {
00208             System.arraycopy(array, head, a, 0, array.length - head);
00209             System.arraycopy(array, 0, a, array.length - head, tail);
00210         }
00211         if (a.length > size) {
00212             a[size] = null;
00213         }
00214         return a;
00215     }
00216
00217     public Object get(int index) {
00218         rangeCheck(index);
00219         return array[convert(index)];
00220     }
00221
00222     public Object set(int index, Object element) {
00223         modCount++;
00224         rangeCheck(index);
00225         int convertedIndex = convert(index);
00226         Object oldValue = array[convertedIndex];
00227         array[convertedIndex] = element;
00228         return oldValue;
00229     }
00230
00231     public boolean add(Object o) {
00232         modCount++;
00233
00234         ensureCapacity(size + 1 + 1);
00235         array[tail] = o;
00236         tail = (tail + 1) % array.length;
00237         size++;
00238         return true;
00239     }
00240
00241
00242
00243
00244     public Object remove(int index) {
00245         modCount++;
00246         rangeCheck(index);
00247         int pos = convert(index);
00248
00249
00250
00251         try {
00252             return array[pos];
00253         } finally {
00254             array[pos] = null;
00255
00256
00257             if (pos == head) {
00258                 head = (head + 1) % array.length;
00259             } else if (pos == tail) {
00260                 tail = (tail - 1 + array.length) % array.length;
00261             } else {
00262                 if ((pos > head) && (pos > tail)) {
00263                     System.arraycopy(array, head, array, head + 1, pos - head);
00264                     head = (head + 1) % array.length;
00265                 } else {
00266                     System.arraycopy(array, pos + 1, array, pos, tail - pos -
00267                         1);
00268                     tail = (tail - 1 + array.length) % array.length;
00269                 }
00270             }
00271             size--;
00272         }
00273     }
00274
00275     public void clear() {
00276         modCount++;
00277
00278         for (int i = 0; i != size; i++) {
00279             array[convert(i)] = null;
00280         }
00281         head = tail = size = 0;
00282     }
00283
00284     public boolean addAll(java.util.Collection c) {
00285         modCount++;
00286         int numNew = c.size();
00287
00288
00289         ensureCapacity(size + numNew + 1);
00290         java.util.Iterator e = c.iterator();
00291         for (int i = 0; i < numNew; i++) {
00292             array[tail] = e.next();
00293             tail = (tail + 1) % array.length;
00294             size++;
00295         }
00296         return numNew != 0;
00297     }
00298
00299     public void add(int index, Object element) {
00300         if (index == size) {
00301             add(element);
00302             return;
00303         }
00304         modCount++;
00305         rangeCheck(index);
00306
00307         ensureCapacity(size + 1 + 1);
00308         int pos = convert(index);
00309         if (pos == head) {
00310             head = (head - 1 + array.length) % array.length;
00311             array[head] = element;
00312         } else if (pos == tail) {
00313             array[tail] = element;
00314             tail = (tail + 1) % array.length;
00315         } else {
00316             if ((pos > head) && (pos > tail)) {
00317                 System.arraycopy(array, pos, array, head - 1, pos - head + 1);
00318                 head = (head - 1 + array.length) % array.length;
00319             } else {
00320                 System.arraycopy(array, pos, array, pos + 1, tail - pos);
00321                 tail = (tail + 1) % array.length;
00322             }
00323             array[pos] = element;
00324         }
00325         size++;
00326     }
00327
00328     public boolean addAll(int index, java.util.Collection c) {
00329         boolean result = true;
00330         Iterator it = c.iterator();
00331         while (it.hasNext()) {
00332             result &= this.add(it.next());
00333         }
00334         return result;
00335     }
00336
00337
00338
00339     private int convert(int index) {
00340         return (index + head) % array.length;
00341     }
00342
00343     private void rangeCheck(int index) {
00344         if ((index >= size) || (index < 0)) {
00345             throw new IndexOutOfBoundsException("Index: " + index + ", Size: " +
00346                 size);
00347         }
00348     }
00349
00350     private void writeObject(java.io.ObjectOutputStream s)
00351         throws java.io.IOException {
00352         s.writeInt(size);
00353         for (int i = 0; i != size; i++) {
00354             s.writeObject(array[convert(i)]);
00355         }
00356     }
00357
00358     private void readObject(java.io.ObjectInputStream s)
00359         throws java.io.IOException, ClassNotFoundException {
00360
00361         head = 0;
00362         size = tail = s.readInt();
00363         if (tail < DEFAULT_SIZE) {
00364             array = new Object[DEFAULT_SIZE];
00365         } else {
00366             array = new Object[tail];
00367         }
00368
00369
00370         for (int i = 0; i < tail; i++)
00371             array[i] = s.readObject();
00372     }
00373 }
