org/objectweb/proactive/ext/security/crypto/CertificateReader.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.ext.security.crypto;
00032
00033 import java.io.FileInputStream;
00034 import java.io.ObjectInputStream;
00035
00036
00043 public class CertificateReader {
00044
00050     public CertificateReader() {
00051     }
00052
00059     public static void main(String[] args) {
00060         //      Provider myProvider = new org.bouncycastle.jce.provider.BouncyCastleProvider();
00061         //              Security.addProvider(myProvider);
00062         String file_name = "";
00063         try {
00064             file_name = args[0];
00065         } catch (Exception e) {
00066             System.out.println("Usage : java CertificateReader mycertificate");
00067         }
00068         try {
00069             FileInputStream fin = new FileInputStream(file_name);
00070             ObjectInputStream in = new ObjectInputStream(fin);
00071             Object object = in.readObject();
00072             in.close();
00073             System.out.println(object.toString());
00074         } catch (Exception e) {
00075             System.out.println("Exception : " + e);
00076         }
00077     }
00078 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
