00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.event; 00032 00033 import org.objectweb.proactive.core.body.UniversalBody; 00034 00035 00036 public class BodyEventProducerImpl extends AbstractEventProducer { 00037 public BodyEventProducerImpl() { 00038 } 00039 00040 public void fireBodyCreated(UniversalBody b) { 00041 if (hasListeners()) { 00042 notifyAllListeners(new BodyEvent(b, BodyEvent.BODY_CREATED)); 00043 } 00044 } 00045 00046 public void fireBodyRemoved(UniversalBody b) { 00047 if (hasListeners()) { 00048 notifyAllListeners(new BodyEvent(b, BodyEvent.BODY_DESTROYED)); 00049 } 00050 } 00051 00052 public void fireBodyChanged(UniversalBody b) { 00053 //System.out.println("fireBodyChanged from AbstractBody active="+b.isActive()); 00054 if (hasListeners()) { 00055 notifyAllListeners(new BodyEvent(b, BodyEvent.BODY_CHANGED)); 00056 } 00057 } 00058 00059 // 00060 // -- implements BodyEventProducer ----------------------------------------------- 00061 // 00062 public void addBodyEventListener(BodyEventListener listener) { 00063 addListener(listener); 00064 } 00065 00066 public void removeBodyEventListener(BodyEventListener listener) { 00067 removeListener(listener); 00068 } 00069 00070 // 00071 // -- PROTECTED METHODS ----------------------------------------------- 00072 // 00073 protected void notifyOneListener(ProActiveListener listener, 00074 ProActiveEvent event) { 00075 BodyEvent bodyEvent = (BodyEvent) event; 00076 switch (bodyEvent.getType()) { 00077 case BodyEvent.BODY_CREATED: 00078 ((BodyEventListener) listener).bodyCreated(bodyEvent); 00079 break; 00080 case BodyEvent.BODY_DESTROYED: 00081 ((BodyEventListener) listener).bodyDestroyed(bodyEvent); 00082 break; 00083 case BodyEvent.BODY_CHANGED: 00084 ((BodyEventListener) listener).bodyChanged(bodyEvent); 00085 break; 00086 } 00087 } 00088 } // end class BodyEventProducerImpl
1.5.1
