org/objectweb/proactive/core/component/Binding.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.component;
00032
00033 import java.io.Serializable;
00034
00035 import org.apache.log4j.Logger;
00036 import org.objectweb.fractal.api.Interface;
00037 import org.objectweb.proactive.core.util.log.Loggers;
00038 import org.objectweb.proactive.core.util.log.ProActiveLogger;
00039
00040
00048 public class Binding implements Serializable {
00049     private static Logger logger = ProActiveLogger.getLogger(Loggers.COMPONENTS);
00050     private final ProActiveInterface clientInterface;
00051     private final ProActiveInterface serverInterface;
00052     private final String clientInterfaceName;
00053
00059     public Binding(final Interface clientInterface, String clientItfName,
00060         final Interface serverInterface) {
00061         this.clientInterface = (ProActiveInterface) clientInterface;
00062         this.clientInterfaceName = clientItfName;
00063         this.serverInterface = (ProActiveInterface) serverInterface;
00064     }
00065
00069     public Interface getClientInterface() {
00070         return clientInterface;
00071     }
00072
00076     public Interface getServerInterface() {
00077         if (logger.isDebugEnabled()) {
00078             logger.debug("returning " + serverInterface.getClass().getName());
00079         }
00080         return serverInterface;
00081     }
00082
00088     public String getClientInterfaceName() {
00089         return clientInterfaceName;
00090     }
00091 }
Generated on Mon Jan 22 15:16:06 2007 for ProActive by  doxygen 1.5.1
