00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.ext.benchsocket; 00032 00033 import java.io.IOException; 00034 import java.io.Serializable; 00035 import java.net.ServerSocket; 00036 import java.net.Socket; 00037 import java.rmi.server.RMIClientSocketFactory; 00038 import java.rmi.server.RMIServerSocketFactory; 00039 00040 00041 public class BenchSocketFactory extends BenchFactory 00042 implements RMIServerSocketFactory, RMIClientSocketFactory, Serializable { 00043 //protected ArrayList streamList; 00044 protected static boolean measure = true; 00045 00046 public ServerSocket createServerSocket(int port) throws IOException { 00047 return new BenchServerSocket(port, this); //ServerSocket(port); 00048 } 00049 00050 public Socket createSocket(String host, int port) throws IOException { 00051 return new BenchClientSocket(host, port, this); 00052 } 00053 00054 public static void startMeasure() { 00055 BenchSocketFactory.measure = true; 00056 } 00057 00058 public static void endMeasure() { 00059 BenchSocketFactory.measure = false; 00060 } 00061 }
1.5.1
