00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.xml.handler; 00032 00033 import org.objectweb.proactive.core.xml.io.Attributes; 00034 00035 00044 public class BasicUnmarshaller implements UnmarshallerHandler { 00045 protected Object resultObject; 00046 protected boolean isResultValid = true; 00047 00048 // 00049 // -- CONSTRUCTORS ----------------------------------------------- 00050 // 00051 public BasicUnmarshaller() { 00052 } 00053 00054 // 00055 // -- PUBLIC METHODS ----------------------------------------------- 00056 // 00057 // 00058 // -- implements UnmarshallerHandler ------------------------------------------------------ 00059 // 00060 public Object getResultObject() throws org.xml.sax.SAXException { 00061 if (!isResultValid) { 00062 throw new org.xml.sax.SAXException("The result object is not valid"); 00063 } 00064 Object o = resultObject; 00065 resultObject = null; 00066 isResultValid = false; 00067 return o; 00068 } 00069 00070 public void startContextElement(String name, Attributes attributes) 00071 throws org.xml.sax.SAXException { 00072 } 00073 00074 // 00075 // -- implements XMLHandler ------------------------------------------------------ 00076 // 00077 public void startElement(String name, Attributes attributes) 00078 throws org.xml.sax.SAXException { 00079 } 00080 00081 public void endElement(String name) throws org.xml.sax.SAXException { 00082 } 00083 00084 public void readValue(String value) throws org.xml.sax.SAXException { 00085 } 00086 00087 public void startPrefixMapping(String prefix, String uri) 00088 throws org.xml.sax.SAXException { 00089 } 00090 00091 public void endPrefixMapping(String prefix) throws org.xml.sax.SAXException { 00092 } 00093 00094 // 00095 // -- PROTECTED METHODS ------------------------------------------------------ 00096 // 00097 protected void setResultObject(Object value) { 00098 isResultValid = true; 00099 resultObject = value; 00100 } 00101 00102 protected boolean checkNonEmpty(String s) { 00103 return (s != null) && (s.length() > 0); 00104 } 00105 00106 // 00107 // -- PRIVATE METHODS ------------------------------------------------------ 00108 // 00109 }
