org/objectweb/proactive/core/xml/handler/BasicUnmarshallerDecorator.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.core.xml.handler;
00032
00033 import org.objectweb.proactive.core.xml.io.Attributes;
00034
00035
00044 public class BasicUnmarshallerDecorator extends AbstractUnmarshallerDecorator {
00045     protected Object resultObject;
00046     protected boolean isResultValid = true;
00047
00048     //
00049     // -- CONSTRUCTORS -----------------------------------------------
00050     //
00051     public BasicUnmarshallerDecorator(boolean lenient) {
00052         super(lenient);
00053     }
00054
00055     public BasicUnmarshallerDecorator() {
00056         super();
00057     }
00058
00059     //
00060     // -- PUBLIC METHODS -----------------------------------------------
00061     //
00062     //
00063     // -- implements UnmarshallerHandler ------------------------------------------------------
00064     //
00065     public Object getResultObject() throws org.xml.sax.SAXException {
00066         if (!isResultValid) {
00067             throw new org.xml.sax.SAXException("The result object is not valid");
00068         }
00069         Object o = resultObject;
00070         resultObject = null;
00071         isResultValid = false;
00072         return o;
00073     }
00074
00075     public void startContextElement(String name, Attributes attributes)
00076         throws org.xml.sax.SAXException {
00077     }
00078
00079     //
00080     // -- PROTECTED METHODS ------------------------------------------------------
00081     //
00082     protected void notifyEndActiveHandler(String name,
00083         UnmarshallerHandler activeHandler) throws org.xml.sax.SAXException {
00084         setResultObject(activeHandler.getResultObject());
00085     }
00086
00087     protected void setResultObject(Object value) {
00088         isResultValid = true;
00089         resultObject = value;
00090     }
00091
00092     //
00093     // -- PRIVATE METHODS ------------------------------------------------------
00094     //
00095     //
00096     // -- INNER CLASSES ------------------------------------------------------
00097     //
00098 }
Generated on Mon Jan 22 15:16:10 2007 for ProActive by  doxygen 1.5.1
