00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.group.spmd; 00032 00033 import java.io.Serializable; 00034 00035 00041 public class BarrierState implements Serializable { 00042 00044 private int awaitedCalls = 0; 00045 00047 private int receivedCalls = 0; 00048 00053 public int getAwaitedCalls() { 00054 return this.awaitedCalls; 00055 } 00056 00061 public int getReceivedCalls() { 00062 return this.receivedCalls; 00063 } 00064 00069 public void setAwaitedCalls(int nbCalls) { 00070 this.awaitedCalls = nbCalls; 00071 } 00072 00076 public void incrementReceivedCalls() { 00077 this.receivedCalls++; 00078 } 00079 }
1.5.1
