org/objectweb/proactive/scheduler/Agent.java
00001 /*
00002  * ################################################################
00003  *
00004  * ProActive: The Java(TM) library for Parallel, Distributed,
00005  *            Concurrent computing with Security and Mobility
00006  *
00007  * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis
00008  * Contact: proactive@objectweb.org
00009  *
00010  * This library is free software; you can redistribute it and/or
00011  * modify it under the terms of the GNU Lesser General Public
00012  * License as published by the Free Software Foundation; either
00013  * version 2.1 of the License, or any later version.
00014  *
00015  * This library is distributed in the hope that it will be useful,
00016  * but WITHOUT ANY WARRANTY; without even the implied warranty of
00017  * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
00018  * Lesser General Public License for more details.
00019  *
00020  * You should have received a copy of the GNU Lesser General Public
00021  * License along with this library; if not, write to the Free Software
00022  * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307
00023  * USA
00024  *
00025  *  Initial developer(s):               The ProActive Team
00026  *                        http://www.inria.fr/oasis/ProActive/contacts.html
00027  *  Contributor(s):
00028  *
00029  * ################################################################
00030  */
00031 package org.objectweb.proactive.scheduler;
00032
00033 import java.util.HashMap;
00034 import java.util.Iterator;
00035 import java.util.Set;
00036
00037
00038 public class Agent {
00039     public Agent() {
00040     }
00041
00042     public Agent(HashMap systemProperties) {
00043         Set keySet = systemProperties.keySet();
00044         Iterator iterator = keySet.iterator();
00045
00046         while (iterator.hasNext()) {
00047             String key = (String) iterator.next();
00048             String value = (String) systemProperties.get(key);
00049
00050             System.setProperty(key, value);
00051         }
00052     }
00053
00054     public void ping() {
00055     }
00056 }
Generated on Mon Jan 22 15:16:11 2007 for ProActive by  doxygen 1.5.1
