00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.body; 00032 00033 import java.io.IOException; 00034 import java.util.HashMap; 00035 import java.util.Map; 00036 00037 import org.objectweb.proactive.core.UniqueID; 00038 import org.objectweb.proactive.core.component.request.Shortcut; 00039 import org.objectweb.proactive.core.exceptions.NonFunctionalException; 00040 import org.objectweb.proactive.core.exceptions.manager.NFEListener; 00041 import org.objectweb.proactive.core.exceptions.manager.NFEListenerList; 00042 00043 00058 public abstract class AbstractUniversalBody implements UniversalBody, 00059 java.io.Serializable { 00060 // 00061 // -- PROTECTED MEMBERS ----------------------------------------------- 00062 // 00063 00065 protected UniqueID bodyID; 00066 00069 protected BodyMap location; 00070 00072 protected String nodeURL; 00073 00075 protected transient UniversalBody remoteBody; 00076 protected RemoteBodyFactory remoteBodyFactory; 00077 protected String jobID; 00078 protected Map shortcuts = null; // key = functionalItfID, value=shortcut 00079 00080 // 00081 // -- PRIVATE MEMBERS ----------------------------------------------- 00082 // 00083 // 00084 // -- CONSTRUCTORS ----------------------------------------------- 00085 // 00086 00091 public AbstractUniversalBody() { 00092 } 00093 00100 public AbstractUniversalBody(String nodeURL, 00101 RemoteBodyFactory remoteBodyFactory, String jobID) { 00102 this.nodeURL = nodeURL; 00103 this.bodyID = new UniqueID(); 00104 this.location = new BodyMap(); 00105 this.jobID = jobID; 00106 this.remoteBodyFactory = remoteBodyFactory; 00107 this.remoteBody = remoteBodyFactory.newRemoteBody(this); 00108 } 00109 00110 // 00111 // -- PUBLIC METHODS ----------------------------------------------- 00112 // 00113 // 00114 // -- implements UniversalBody ----------------------------------------------- 00115 // 00116 public String getJobID() { 00117 return jobID; 00118 } 00119 00120 public String getNodeURL() { 00121 return nodeURL; 00122 } 00123 00124 public BodyAdapter getRemoteAdapter() { 00125 return (BodyAdapter) remoteBody; 00126 } 00127 00128 public UniqueID getID() { 00129 return bodyID; 00130 } 00131 00132 public void updateLocation(UniqueID bodyID, UniversalBody body) { 00133 location.updateBody(bodyID, body); 00134 } 00135 00136 // 00137 // -- PROTECTED METHODS ----------------------------------------------- 00138 // 00139 // 00140 // -- PRIVATE METHODS ----------------------------------------------- 00141 // 00142 private void writeObject(java.io.ObjectOutputStream out) 00143 throws java.io.IOException { 00144 out.defaultWriteObject(); 00145 } 00146 00147 private void readObject(java.io.ObjectInputStream in) 00148 throws java.io.IOException, ClassNotFoundException { 00149 in.defaultReadObject(); 00150 //System.out.println("@@@@@@@@@@@@@@@@@@" + this.jobID); 00151 if (bodyID == null) { 00152 // it may happen that the bodyID is set to null before serialization if we want to 00153 // create a copy of the Body that is distinct from the original 00154 bodyID = new UniqueID(); 00155 } 00156 00157 // remoteBody is transient so we recreate it here 00158 this.remoteBody = remoteBodyFactory.newRemoteBody(this); 00159 } 00160 00161 /* 00162 * 00163 * @see org.objectweb.proactive.core.body.UniversalBody#createShortcut(org.objectweb.proactive.core.component.request.Shortcut) 00164 */ 00165 public void createShortcut(Shortcut shortcut) throws IOException { 00166 if (shortcuts == null) { 00167 shortcuts = new HashMap(); 00168 } 00169 shortcuts.put(shortcut.getLinkedInterfaceID(), shortcut); 00170 } 00171 00172 // NFEProducer implementation 00173 private NFEListenerList nfeListeners = null; 00174 00175 public void addNFEListener(NFEListener listener) { 00176 if (nfeListeners == null) { 00177 nfeListeners = new NFEListenerList(); 00178 } 00179 nfeListeners.addNFEListener(listener); 00180 } 00181 00182 public void removeNFEListener(NFEListener listener) { 00183 if (nfeListeners != null) { 00184 nfeListeners.removeNFEListener(listener); 00185 } 00186 } 00187 00188 public int fireNFE(NonFunctionalException e) { 00189 if (nfeListeners != null) { 00190 return nfeListeners.fireNFE(e); 00191 } 00192 return 0; 00193 } 00194 }
1.5.1
