00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process; 00032 00033 import org.objectweb.proactive.core.descriptor.services.UniversalService; 00034 import org.objectweb.proactive.core.process.filetransfer.FileTransferWorkShop; 00035 import org.objectweb.proactive.core.util.RemoteProcessMessageLogger; 00036 00037 import java.util.ArrayList; 00038 00039 00048 public abstract class AbstractSequentialListProcessDecorator 00049 implements ExternalProcessDecorator { 00050 boolean isFirstElementService = false; 00051 00052 //Array of processes 00053 protected ArrayList processes; 00054 00055 // position of the next process to return 00056 protected int currentProcessRank = 0; 00057 00058 public AbstractSequentialListProcessDecorator() { 00059 processes = new ArrayList(); 00060 } 00061 00066 public void addProcessToList(ExternalProcess process) { 00067 this.processes.add(process); 00068 } 00069 00074 public void addServiceToList(UniversalService service) { 00075 this.processes.add(service); 00076 } 00077 00083 public void addProcessToList(int rank, ExternalProcess process) { 00084 this.processes.add(rank, process); 00085 } 00086 00092 public void addServiceToList(int rank, UniversalService service) { 00093 this.processes.add(rank, service); 00094 } 00095 00100 public ExternalProcess getFirstProcess() { 00101 currentProcessRank++; 00102 return (ExternalProcess) processes.get(0); 00103 } 00104 00109 public UniversalService getFirstService() { 00110 currentProcessRank++; 00111 return (UniversalService) processes.get(0); 00112 } 00113 00118 public ExternalProcess getNextProcess() { 00119 ExternalProcess res = null; 00120 if (currentProcessRank < processes.size()) { 00121 res = (ExternalProcess) processes.get(currentProcessRank); 00122 currentProcessRank++; 00123 } 00124 return res; 00125 } 00126 00127 // 00128 //--------------------------Implements ExternalProcessDecorator---------------------- 00129 00133 public ExternalProcess getTargetProcess() { 00134 return ((ExternalProcessDecorator) processes.get(currentProcessRank)).getTargetProcess(); 00135 } 00136 00140 public void setTargetProcess(ExternalProcess targetProcess) { 00141 ((ExternalProcessDecorator) processes.get(currentProcessRank)).setTargetProcess(targetProcess); 00142 } 00143 00147 public int getCompositionType() { 00148 return ((ExternalProcess) processes.get(currentProcessRank)).getCompositionType(); 00149 } 00150 00154 public void setCompositionType(int compositionType) { 00155 ((ExternalProcessDecorator) processes.get(currentProcessRank)).setCompositionType(compositionType); 00156 } 00157 00158 public FileTransferWorkShop getFileTransferWorkShopRetrieve() { 00159 00160 /* TODO Check if this is the correct place 00161 * implement this. Then implement it 00162 */ 00163 return null; 00164 } 00165 00166 public FileTransferWorkShop getFileTransferWorkShopDeploy() { 00167 00168 /* TODO Check if this is the correct place 00169 * implement this. Then implement it 00170 */ 00171 return null; 00172 } 00173 00174 public void startFileTransfer() { 00175 00176 /* TODO Check if this is the correct place 00177 * implement this. Then implement it 00178 */ 00179 } 00180 00181 public boolean isRequiredFileTransferDeployOnNodeCreation() { 00182 00183 /* TODO Check if this is the correct place 00184 * implement this. Then implement it 00185 */ 00186 return false; 00187 } 00188 00192 public void closeStream() { 00193 ((ExternalProcess) processes.get(currentProcessRank)).closeStream(); 00194 } 00195 00199 public RemoteProcessMessageLogger getInputMessageLogger() { 00200 return ((ExternalProcess) processes.get(currentProcessRank)).getInputMessageLogger(); 00201 } 00202 00206 public RemoteProcessMessageLogger getErrorMessageLogger() { 00207 return ((ExternalProcess) processes.get(currentProcessRank)).getErrorMessageLogger(); 00208 } 00209 00213 public MessageSink getOutputMessageSink() { 00214 return ((ExternalProcess) processes.get(currentProcessRank)).getOutputMessageSink(); 00215 } 00216 00220 public void setInputMessageLogger( 00221 RemoteProcessMessageLogger inputMessageLogger) { 00222 for (int i = 0; i < processes.size(); i++) { 00223 ((ExternalProcess) processes.get(i)).setInputMessageLogger(inputMessageLogger); 00224 } 00225 } 00226 00230 public void setErrorMessageLogger( 00231 RemoteProcessMessageLogger errorMessageLogger) { 00232 for (int i = 0; i < processes.size(); i++) { 00233 ((ExternalProcess) processes.get(i)).setErrorMessageLogger(errorMessageLogger); 00234 } 00235 } 00236 00240 public void setOutputMessageSink(MessageSink outputMessageSink) { 00241 for (int i = 0; i < processes.size(); i++) { 00242 ((ExternalProcess) processes.get(i)).setOutputMessageSink(outputMessageSink); 00243 } 00244 } 00245 00249 public String[] getEnvironment() { 00250 return ((ExternalProcess) processes.get(currentProcessRank)).getEnvironment(); 00251 } 00252 00256 public void setEnvironment(String[] environment) { 00257 ((ExternalProcess) processes.get(currentProcessRank)).setEnvironment(environment); 00258 } 00259 00263 public String getUsername() { 00264 return ((ExternalProcess) processes.get(currentProcessRank)).getUsername(); 00265 } 00266 00270 public void setUsername(String username) { 00271 ((ExternalProcess) processes.get(currentProcessRank)).setUsername(username); 00272 } 00273 00277 public String getCommand() { 00278 return null; 00279 } 00280 00284 public String getProcessId() { 00285 return "ps"; 00286 } 00287 00291 public int getNodeNumber() { 00292 return ((ExternalProcessDecorator) processes.get(currentProcessRank)).getNodeNumber(); 00293 } 00294 00298 public UniversalProcess getFinalProcess() { 00299 return ((ExternalProcessDecorator) processes.get(currentProcessRank)).getFinalProcess(); 00300 } 00301 00302 public ArrayList getListProcess() { 00303 return this.processes; 00304 } 00305 00309 public void stopProcess() { 00310 ((ExternalProcess) processes.get(currentProcessRank)).stopProcess(); 00311 } 00312 00316 public int waitFor() throws InterruptedException { 00317 int status = 0; 00318 status = ((ExternalProcess) processes.get(currentProcessRank)).waitFor(); 00319 return status; 00320 } 00321 00325 public boolean isStarted() { 00326 boolean started = true; 00327 started = ((ExternalProcess) processes.get(currentProcessRank)).isStarted(); 00328 return started; 00329 } 00330 00334 public boolean isFinished() { 00335 boolean finished = true; 00336 finished = ((ExternalProcess) processes.get(currentProcessRank)).isFinished(); 00337 return finished; 00338 } 00339 00340 public boolean isSequential() { 00341 return true; 00342 } 00343 00347 public void setCommandPath(String path) { 00348 ((ExternalProcess) processes.get(currentProcessRank)).setCommandPath(path); 00349 } 00350 00354 public String getCommandPath() { 00355 return ((ExternalProcess) processes.get(currentProcessRank)).getCommandPath(); 00356 } 00357 00358 // 00359 //-----------------protected methods---------------------------------------- 00360 // 00361 protected abstract ExternalProcess createProcess(); 00362 00363 public int exitValue() throws IllegalThreadStateException { 00364 // TODO Auto-generated method stub 00365 return 0; 00366 } 00367 00368 public void setStarted(boolean isStarted) { 00369 // TODO Auto-generated method stub 00370 } 00371 00372 public void setFinished(boolean isStarted) { 00373 // TODO Auto-generated method stub 00374 } 00375 00376 public boolean isFirstElementIsService() { 00377 return isFirstElementService; 00378 } 00379 00380 public void setFirstElementIsService(boolean isFirstElementIsService) { 00381 this.isFirstElementService = isFirstElementIsService; 00382 } 00383 }
1.5.1
