00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.body.proxy; 00032 00033 //import java.util.HashMap; 00034 00035 import org.apache.log4j.Logger; 00036 import org.objectweb.proactive.core.exceptions.NonFunctionalException; 00037 import org.objectweb.proactive.core.exceptions.manager.NFEListener; 00038 import org.objectweb.proactive.core.exceptions.manager.NFEListenerList; 00039 import org.objectweb.proactive.core.exceptions.manager.NFEProducer; 00040 import org.objectweb.proactive.core.mop.MethodCall; 00041 import org.objectweb.proactive.core.mop.Proxy; 00042 import org.objectweb.proactive.core.util.log.Loggers; 00043 import org.objectweb.proactive.core.util.log.ProActiveLogger; 00044 00045 00046 public abstract class AbstractProxy implements Proxy, java.io.Serializable, 00047 NFEProducer { 00048 // Get logger 00049 protected static Logger logger = ProActiveLogger.getLogger(Loggers.NFE); 00050 00051 // table of handlers associated to proxy 00052 //private HashMap proxyLevel; 00053 00054 // 00055 // -- CONSTRUCTORS ----------------------------------------------- 00056 // 00057 public AbstractProxy() { 00058 } 00059 00060 // 00061 // -- METHODS ---------------------------------------------------- 00062 // 00063 00075 protected static boolean isAsynchronousCall(MethodCall mc) { 00076 return mc.isAsynchronousWayCall(); 00077 } 00078 00086 protected static boolean isOneWayCall(MethodCall mc) { 00087 return mc.isOneWayCall(); 00088 } 00089 00090 // /** 00091 // * Get information about the handlerizable object 00092 // * @return information about the handlerizable object 00093 // */ 00094 // public String getHandlerizableInfo() throws java.io.IOException { 00095 // return "PROXY of CLASS ["+ this.getClass() +"]"; 00096 // } 00097 // 00098 // /** Give a reference to a local map of handlers 00099 // * @return A reference to a map of handlers 00100 // */ 00101 // public HashMap getHandlersLevel() throws java.io.IOException { 00102 // return proxyLevel; 00103 // } 00104 // 00105 // /** 00106 // * Clear the local map of handlers 00107 // */ 00108 // public void clearHandlersLevel() throws java.io.IOException { 00109 // proxyLevel.clear(); 00110 // } 00111 // 00112 // /** Set a new handler within the table of the Handlerizable Object 00113 // * @param handler A handler associated with a class of non functional exception. 00114 // * @param exception A class of non functional exception. It is a subclass of <code>NonFunctionalException</code>. 00115 // */ 00116 // public void setExceptionHandler(Handler handler, Class exception) 00117 // throws java.io.IOException { 00118 // // add handler to proxy level 00119 // if (proxyLevel == null) { 00120 // proxyLevel = new HashMap(); 00121 // } 00122 // proxyLevel.put(exception, handler); 00123 // } 00124 // 00125 // /** Remove a handler from the table of the Handlerizable Object 00126 // * @param exception A class of non functional exception. It is a subclass of <code>NonFunctionalException</code>. 00127 // * @return The removed handler or null 00128 // */ 00129 // public Handler unsetExceptionHandler(Class exception) 00130 // throws java.io.IOException { 00131 // // remove handler from proxy level 00132 // if (proxyLevel != null) { 00133 // Handler handler = (Handler) proxyLevel.remove(exception); 00134 // return handler; 00135 // } else { 00136 // if (logger.isDebugEnabled()) { 00137 // logger.debug("[NFE_WARNING] No handler for [" + 00138 // exception.getName() + "] can be removed from PROXY level"); 00139 // } 00140 // return null; 00141 // } 00142 // } 00143 // NFEProducer implementation 00144 private NFEListenerList nfeListeners = null; 00145 00146 public void addNFEListener(NFEListener listener) { 00147 if (nfeListeners == null) { 00148 nfeListeners = new NFEListenerList(); 00149 } 00150 nfeListeners.addNFEListener(listener); 00151 } 00152 00153 public void removeNFEListener(NFEListener listener) { 00154 if (nfeListeners != null) { 00155 nfeListeners.removeNFEListener(listener); 00156 } 00157 } 00158 00159 public int fireNFE(NonFunctionalException e) { 00160 if (nfeListeners != null) { 00161 return nfeListeners.fireNFE(e); 00162 } 00163 return 0; 00164 } 00165 }
 1.5.1
