00001
00002
00003
00004
00005
00006
00007
00008
00009
00010
00011
00012
00013
00014
00015
00016
00017
00018
00019
00020
00021
00022
00023
00024
00025
00026
00027
00028
00029
00030
00031 package org.objectweb.proactive.core.process;
00032
00033 import org.objectweb.proactive.core.process.filetransfer.CopyProtocol;
00034 import org.objectweb.proactive.core.process.filetransfer.FileDependant;
00035 import org.objectweb.proactive.core.process.filetransfer.FileTransferWorkShop;
00036 import org.objectweb.proactive.core.util.RemoteProcessMessageLogger;
00037
00038
00039 public abstract class AbstractExternalProcessDecorator
00040     extends AbstractExternalProcess implements ExternalProcessDecorator {
00041     protected ExternalProcess targetProcess;
00042     private int compositionType = APPEND_TO_COMMAND_COMPOSITION;
00043
00044
00045
00046
00047     public AbstractExternalProcessDecorator() {
00048         super();
00049     }
00050
00051     public AbstractExternalProcessDecorator(ExternalProcess targetProcess) {
00052         this(targetProcess, APPEND_TO_COMMAND_COMPOSITION);
00053     }
00054
00055     public AbstractExternalProcessDecorator(ExternalProcess targetProcess,
00056         int compositionType) {
00057         super();
00058         setTargetProcess(targetProcess);
00059         this.compositionType = compositionType;
00060     }
00061
00062
00063
00064
00065     public ExternalProcess getTargetProcess() {
00066         return targetProcess;
00067     }
00068
00069     public void setTargetProcess(ExternalProcess targetProcess) {
00070         checkStarted();
00071         this.targetProcess = targetProcess;
00072         setInputMessageLogger(targetProcess.getInputMessageLogger());
00073         setErrorMessageLogger(targetProcess.getErrorMessageLogger());
00074         setOutputMessageSink(targetProcess.getOutputMessageSink());
00075     }
00076
00077     public int getCompositionType() {
00078         return compositionType;
00079     }
00080
00081     public void setCompositionType(int compositionType) {
00082         checkStarted();
00083         this.compositionType = compositionType;
00084     }
00085
00086
00087
00088
00089     protected void toString(StringBuilder sb) {
00090         super.toString(sb);
00091         sb.append(" ---- Target Process ----- \n");
00092         if (targetProcess == null) {
00093             sb.append(" NOT DEFINED \n");
00094         } else {
00095             sb.append(targetProcess.toString());
00096         }
00097         sb.append(" -------------- \n");
00098     }
00099
00100     protected String buildCommand() {
00101         if ((compositionType == SEND_TO_OUTPUT_STREAM_COMPOSITION) ||
00102                 (compositionType == GIVE_COMMAND_AS_PARAMETER) ||
00103                 (compositionType == COPY_FILE_AND_APPEND_COMMAND)) {
00104             return internalBuildCommand();
00105         } else {
00106             if (targetProcess != null) {
00107
00108
00109
00110                 String targetCommand = targetProcess.getCommand();
00111                 if (targetProcess.getCompositionType() == COPY_FILE_AND_APPEND_COMMAND) {
00112                     handleCopyFile();
00113                 }
00114                 return internalBuildCommand() + targetCommand;
00115             } else {
00116                 return internalBuildCommand();
00117             }
00118         }
00119     }
00120
00121     protected abstract String internalBuildCommand();
00122
00123     protected void internalStartProcess(String command)
00124         throws java.io.IOException {
00125         super.internalStartProcess(command);
00126         if (compositionType == SEND_TO_OUTPUT_STREAM_COMPOSITION) {
00127             try {
00128                 Thread.sleep(3000);
00129             } catch (InterruptedException e) {
00130             }
00131
00132
00133             outputMessageSink.setMessage(targetProcess.getCommand());
00134         }
00135     }
00136
00137     protected void handleOutput(java.io.BufferedWriter out) {
00138         if (compositionType == SEND_TO_OUTPUT_STREAM_COMPOSITION) {
00139             if (outputMessageSink == null) {
00140                 outputMessageSink = new SimpleMessageSink();
00141             }
00142         }
00143         super.handleOutput(out);
00144     }
00145
00146     protected void handleCopyFile() {
00147         FileTransferWorkShop ftw = new FileTransferWorkShop(getFileTransferDefaultCopyProtocol());
00148         ftw.setFileTransferStructureDstInfo("hostname", hostname);
00149         ftw.setFileTransferStructureDstInfo("username", username);
00150         try {
00151             ftw.addFileTransfer(((FileDependant) targetProcess).getFileTransfertDefiniton());
00152         } catch (ClassCastException e) {
00153             logger.error(
00154                 "Unable to handle the file transfert dependant process");
00155             return;
00156         }
00157
00158         CopyProtocol cp = ftw.copyProtocolFactory(getFileTransferDefaultCopyProtocol());
00159         cp.startFileTransfer();
00160     }
00161
00162
00163
00164
00165
00169     public static class CompositeMessageLogger
00170         implements RemoteProcessMessageLogger, java.io.Serializable {
00171         private RemoteProcessMessageLogger messageLogger1;
00172         private RemoteProcessMessageLogger messageLogger2;
00173
00174         public CompositeMessageLogger(
00175             RemoteProcessMessageLogger messageLogger1,
00176             RemoteProcessMessageLogger messageLogger2) {
00177             this.messageLogger1 = messageLogger1;
00178             this.messageLogger2 = messageLogger2;
00179         }
00180
00181         public void log(String message) {
00182             messageLogger1.log(message);
00183             messageLogger2.log(message);
00184         }
00185
00186         public void log(Throwable t) {
00187             messageLogger1.log(t);
00188             messageLogger2.log(t);
00189         }
00190
00191         public void log(String message, Throwable t) {
00192             messageLogger1.log(message, t);
00193             messageLogger2.log(message, t);
00194         }
00195     }
00196
00200     public static class CompositeMessageSink implements MessageSink {
00201         private MessageSink messageSink1;
00202         private MessageSink messageSink2;
00203
00204         public CompositeMessageSink(MessageSink messageSink1,
00205             MessageSink messageSink2) {
00206             this.messageSink1 = messageSink1;
00207             this.messageSink2 = messageSink2;
00208         }
00209
00210         public synchronized String getMessage() {
00211             while ((!hasMessage()) && isActive()) {
00212                 try {
00213                     wait(1000);
00214                 } catch (InterruptedException e) {
00215                 }
00216             }
00217             if (messageSink1.hasMessage()) {
00218                 return messageSink1.getMessage();
00219             } else if (messageSink2.hasMessage()) {
00220                 return messageSink1.getMessage();
00221             }
00222             return null;
00223         }
00224
00225         public synchronized void setMessage(String messageToPost) {
00226             messageSink1.setMessage(messageToPost);
00227             notifyAll();
00228         }
00229
00230         public synchronized boolean hasMessage() {
00231             return messageSink1.hasMessage() || messageSink2.hasMessage();
00232         }
00233
00234         public synchronized boolean isActive() {
00235             return messageSink1.isActive() || messageSink2.isActive();
00236         }
00237     }
00238 }
