00001 /* 00002 * ################################################################ 00003 * 00004 * ProActive: The Java(TM) library for Parallel, Distributed, 00005 * Concurrent computing with Security and Mobility 00006 * 00007 * Copyright (C) 1997-2007 INRIA/University of Nice-Sophia Antipolis 00008 * Contact: proactive@objectweb.org 00009 * 00010 * This library is free software; you can redistribute it and/or 00011 * modify it under the terms of the GNU Lesser General Public 00012 * License as published by the Free Software Foundation; either 00013 * version 2.1 of the License, or any later version. 00014 * 00015 * This library is distributed in the hope that it will be useful, 00016 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00017 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00018 * Lesser General Public License for more details. 00019 * 00020 * You should have received a copy of the GNU Lesser General Public 00021 * License along with this library; if not, write to the Free Software 00022 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 00023 * USA 00024 * 00025 * Initial developer(s): The ProActive Team 00026 * http://www.inria.fr/oasis/ProActive/contacts.html 00027 * Contributor(s): 00028 * 00029 * ################################################################ 00030 */ 00031 package org.objectweb.proactive.core.process.filetransfer; 00032 00033 import java.io.IOException; 00034 import java.io.InputStream; 00035 import java.util.ArrayList; 00036 00037 import org.apache.log4j.Logger; 00038 import org.objectweb.proactive.core.process.filetransfer.FileTransferDefinition.DirectoryDescription; 00039 import org.objectweb.proactive.core.process.filetransfer.FileTransferDefinition.FileDescription; 00040 import org.objectweb.proactive.core.process.filetransfer.FileTransferWorkShop; 00041 import org.objectweb.proactive.core.process.filetransfer.FileTransferWorkShop.StructureInformation; 00042 import org.objectweb.proactive.core.util.log.Loggers; 00043 import org.objectweb.proactive.core.util.log.ProActiveLogger; 00044 00045 00054 public abstract class AbstractCopyProtocol implements CopyProtocol { 00055 protected static Logger logger = ProActiveLogger.getLogger(Loggers.DEPLOYMENT_FILETRANSFER); 00056 protected boolean isDefaultProtocol = false; 00057 protected String name; 00058 protected FileTransferDefinition[] fileTransfer; 00059 protected StructureInformation srcInfoParams; 00060 protected StructureInformation dstInfoParams; 00061 protected boolean closeStream = false; 00062 00063 public AbstractCopyProtocol(String name) { 00064 this.name = name; 00065 } 00066 00067 public String getProtocolName() { 00068 return name; 00069 } 00070 00071 public void setProtocolName(String name) { 00072 this.name = name; 00073 } 00074 00075 public boolean isDefaultProtocol() { 00076 return isDefaultProtocol; 00077 } 00078 00079 public void setDefaultProtocol(boolean isDefaultProtocol) { 00080 this.isDefaultProtocol = isDefaultProtocol; 00081 } 00082 00083 public void setFileTransferDefinitions(FileTransferDefinition[] fileTransfer) { 00084 this.fileTransfer = fileTransfer; 00085 } 00086 00087 public void setSrcInfo( 00088 FileTransferWorkShop.StructureInformation srcInfoParams) { 00089 this.srcInfoParams = srcInfoParams; 00090 } 00091 00092 public void setDstInfo( 00093 FileTransferWorkShop.StructureInformation dstInfoParams) { 00094 this.dstInfoParams = dstInfoParams; 00095 } 00096 00101 public boolean isDummyProtocol() { 00102 return false; 00103 } 00104 00113 protected FileDescription[] getHomonymousFiles() { 00114 ArrayList<FileDescription> aList = new ArrayList<FileDescription>(); 00115 00116 for (int i = 0; i < fileTransfer.length; i++) { 00117 FileDescription[] fd = fileTransfer[i].getHomonymousFile(); 00118 for (int j = 0; j < fd.length; j++) 00119 aList.add(fd[j]); 00120 } 00121 00122 return aList.toArray(new FileDescription[0]); 00123 } 00124 00133 protected FileDescription[] getHeteronymousFiles() { 00134 ArrayList<FileDescription> aList = new ArrayList<FileDescription>(); 00135 00136 for (int i = 0; i < fileTransfer.length; i++) { 00137 FileDescription[] fd = fileTransfer[i].getHeteronymousFile(); 00138 for (int j = 0; j < fd.length; j++) 00139 aList.add(fd[j]); 00140 } 00141 00142 return aList.toArray(new FileDescription[0]); 00143 } 00144 00153 protected DirectoryDescription[] getHomonymousDirs() { 00154 ArrayList<FileDescription> aList = new ArrayList<FileDescription>(); 00155 00156 for (int i = 0; i < fileTransfer.length; i++) { 00157 FileDescription[] fd = fileTransfer[i].getHomonymousDir(); 00158 for (int j = 0; j < fd.length; j++) 00159 aList.add(fd[j]); 00160 } 00161 00162 return (DirectoryDescription[]) aList.toArray(new DirectoryDescription[0]); 00163 } 00164 00174 protected DirectoryDescription[] getHeteronymousDirs() { 00175 ArrayList<DirectoryDescription> aList = new ArrayList<DirectoryDescription>(); 00176 00177 for (int i = 0; i < fileTransfer.length; i++) { 00178 DirectoryDescription[] fd = fileTransfer[i].getHeteronymousDir(); 00179 for (int j = 0; j < fd.length; j++) 00180 aList.add(fd[j]); 00181 } 00182 00183 return aList.toArray(new DirectoryDescription[0]); 00184 } 00185 00186 protected FileDescription[] getHeteronymousAll() { 00187 FileDescription[] files = getHeteronymousFiles(); 00188 FileDescription[] dirs = getHeteronymousDirs(); 00189 00190 FileDescription[] all = new FileDescription[files.length + dirs.length]; 00191 00192 for (int i = 0; i < files.length; i++) { 00193 all[i] = files[i]; 00194 } 00195 00196 for (int i = 0; i < dirs.length; i++) { 00197 all[files.length + i] = dirs[i]; 00198 } 00199 00200 return all; 00201 } 00202 00203 protected FileDescription[] getHomonymousAll() { 00204 FileDescription[] files = getHomonymousFiles(); 00205 FileDescription[] dirs = getHomonymousDirs(); 00206 00207 FileDescription[] all = new FileDescription[files.length + dirs.length]; 00208 00209 for (int i = 0; i < files.length; i++) { 00210 all[i] = files[i]; 00211 } 00212 00213 for (int i = 0; i < dirs.length; i++) { 00214 all[files.length + i] = dirs[i]; 00215 } 00216 00217 return all; 00218 } 00219 00225 protected String getErrorMessage(InputStream in) { 00226 StringBuilder sb = new StringBuilder(); 00227 byte[] b = new byte[1000]; 00228 int read; 00229 while (true) { 00230 try { 00231 read = in.read(b); 00232 if (read < 0) { 00233 break; 00234 } 00235 00236 sb.append(new String(b, 0, read)); 00237 } catch (IOException e1) { 00238 e1.printStackTrace(); 00239 } 00240 } 00241 return sb.toString(); 00242 } 00243 }
1.5.1
